Test No. VD02 View transient response of a simply
supported square plate subjected to periodic forced vibration .
Definition
A simply supported thin square plate 10 x 10 x 0.05 m is subject to uniform pressure
P=100 Pa which changes in time as the following function.(1)
Where,
Excitation frequency.
Sixteen (16) modes are used to approximate dynamics solution and 2% modal damping is
assumed in all modes.
The material properties are:
Properties
Value
Modulus of Elasticity
2.e+11 Pa
Poisson's Ratio
0.3
Density
8.e+3 kg/m3
Results
The plate is simulated as a 3D solid body. Spot-lines were created at the mid-plane
of the plate in order to apply hinge supports (Figure 1). In order to simulate periodic load
changing according to the formula above, two pressure loads were applied to the
plate:
to the top surface of the plate, and
to the bottom surface of the plate
The following table contains typical values at steady-state portion of the dynamics
solution (Figure 2).
Deflection Y, mm
Surface Stress, MPa
-2.886
2.062
SimSolid, solid model
-2.863
2.018
Reference, thin plate model
1 Test 13P from
NAFEMS Publication R0016, “Selected Benchmarks for Forced Vibration” J. Maguire,
D.J. Dawswell, L. Gould
